WinCC/WebUX
userxyz
May 2002
any
2,768
Hello,
At a customer WinCC 7.3 is used and around 30 web navigator cliënts are in use. Because of Windows 10 we need to upgrade to WinCC 7.4. So all web navigators have to be upgraded as well. I've seen that WinCC also has some option called WebUX. Could this replace the web navigator ? Anyone experiences with this ? Or is this custom webpages to build ?
Thanks,
Kind regards,
Gerry
Gerry,
I'm not sure about the WebUX, because I haven't used it.
However we are using WinCC v7.4 with Windows 10, and Windows have just done a security update, and now the web navigator doesn't work, because of the Windows update.
Our IT guys have had to remove the latest Windows update on all the PC's that use the web navigator.
We have contacted Siemens, and they have no time set for a WinCC update to allow this Windows update.
I hope all of that makes sense.
Cheers
Mark
WebUX doesn't 100% replace web navigator, but it goes towards a similar goal. Web Navigator has like 99% of the functionality of a full WinCC Client, but does it in ActiveX, which means it needs Windows and IE. WebUX does it all in HTML5, which means it can run on any browser and any system. The downside is that it only does certain objects. It covers the majority of functionality, but not everything is possible.
You don't need to do any customer web page work, I think it's pretty much all handled by right click type options.
Hello,
Thanks,
Kind regards,
Gerry
I'm using Windows 10 X64 also but only for the webnavigator.
You can install it on Windows 10 by browsing to your webserver in Internet Explorer. Make sure the option Active X is on.
Then you can download the installer from the webserver and install it on Windows 10.
I'm running WinCC 7.3 Update 16 now on Windows 10 X64.
I tried to install it from the WinCC Setup, but this shows the error that it is not support for Windows 10.
Maybe this is enough for your to update only the Windows 10 PC's that using the webnavigator client.
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
61
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
55
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
75
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
75
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
147
