WinCC with MS Access
shandra_ck
Jan 2005
Malaysia
63
Hi All,
I am having some problem with WinCC Version 5.0. I need to create recipe page with editing function (search, edit, delete,new) and looking for option other than the user archieve.
My choices was:
1. Text file
(I am able to write to the file but unable to retrieve them.)
2. Link up with Ms. Access (I am not sure this can be done, i hope I can get some feedback on this).Still testing.
Any other option that I can use?
Please guide
Thank you
Best regards,
Shandra
Try to look at WinCC.net . For WinCC V5 manual (configuration book 1), you will find the way to read and write data to text file.
Thanks Coa,
I did went through the text file format. It works. But the problem is I need to retrieve data based on a key word then edit or delete. Its a bit difficult. I was trying with array but still unsuccessul.
Regards,
Shandra
I am working on a project where I need to create a visualization screen (HMI Panel or PC) using wincc tia portal v16. It will be connected to the...
567
Hi Does anyone know if WinCC basic version has functionality in it for ACCESS CONTROL? By that, I mean we want the HMI to have a lock-out...
1,181
I am new to WinCC and have limited experience with SQL servers and databases, but I have been presented with a problem with the overwriting of...
1,316
Dear Folks, I have recently joint a new company, my first task is to prepare a new standbys server that have our main WinCC project. The WinCC...
5,158
Hi, i am working on a project. and its HMI is remotely control so for that I am using the option of smart server in WinCC flexible but I am...
2,808
