WinCC with S7-300 and SLC500/4
jm76
Oct 2009
Barcelona
29
Hello everybody
Somebody know if is possible connect to Wincc with a S7-300 and SLC500/4.
Because wincc have a port MPI/DP the same that S7-300, but the SLC500 not have the same protocol..
Thanks advanced
I have the same problem, I want to connect 2 PLC :
*S7-3005316-2DP (with free ethernet port)
*AB SLC 504
I want to connect them via WINCC, it s possible?
Hi
Yes, this is possible.
Wincc V7 have the following drivers
Allen Bradley - Ethernet IP
SIMATIC TI Ethernet Layer 4
SIMATIC S7 Protocol Suite
Thank's for the answer,
for th S7-300 i have an ethernet free port but for AB SLC504 i have an RS232 port.,i think that the DF1 is the appropriate drivers.
You welcome.
I don´t know if is possible use RS-232 direct to Wincc, I think this not possible.
But if you don´t have ethernet card for your SLC 504, so you can use OPC, with this, you will don´t have any problem.
I think that's possible with the DF1 protocol.
For the OPC solution, it's my last issue, i think to add a new module of ethernet port,have you any idea what's the model and it's possible or not?
thanks
This link is for PLC-5 not SLC!
So you can change the CPU!
Here, there is a lot of people that are very good!
I hope they give their opinion
Hello! I have an old system s7 300 and with Wincc RT Professional.Windows PC with Wincc RT got crashed and I want to up the SCADA on new PC. I...
2,026
Hi, I have a PC with WinCC 7.4 and a PLC 315-2DP with 343-1 card. I cannot get connection to the PLC in the tag management while settings of the...
2,107
Hello, I'm Alex from Spain (sorry for my bad english). Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours...
1,603
Hi Everyone, I want to know how we show the profibus slave alarm in wincc flexible 2008.when any one profibus slave do not communicate or give...
3,663
Dear All, i want to know how we Date and Time set and Change from HMI MP277 use Wincc Flexible.PLC is S7 300 CPU 315 2-DP.i use SFC0,SFC1 but...
5,724
