wincc
reza.meftahi
Aug 2010
karaj
hi friends.i installed wincc v6.0 sp4 .when i want to attribute dynamic dialog to an object it doesnt work and wincc returns "wrong expression/formula ".
please help me.
I have no WinCC at hand to test it, but try this:
Since your NewTag1 is a 16 bit word, try to shift from 'BOOLEAN' to 'BIT'. Then you get a new input field where you can specify which bit number you want to use.
NB! Byte x+0 has address 15-8, byte x+1 has address 7-0.
Kalle
OK, now I think I know why:
You are editing the background color of a group of symbols. Try to ungroup and edit the symbols who need color shift individually.
The 'normal' way to achieve what you want here, is to draw bitmaps in different colors and link them to a dynamic valued tag.
Kalle
dear kalle ,i checked this procedure on standard objects (like circle) and it was same problem.it seems i have problem with making dynamic for all objects.
best regard
reza
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
73
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
62
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
77
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
78
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
153
