[WinCCFlex] MP377 e-mail scripting
jeroendeweerd
Sep 2012
Overijssel
I am using the time interval logging functionality on a MP377 panel. Log files are periodically copied and stored onto a flash card, so far so good.
Within this last copy- event we also want to send the file as an e-mail attachment to an mail recepient. That`s where the problem starts. The built-in 'sendemail' function does not support any sort of attachments.
Also our internet provider does not support SMTP functionalities, so sending an e-mail with the sendemail will never work, while CDO has capabilities to deliver this e-mail without making use of an external smtp server.
Within a CDO it is possible to create a script wich does the trick, tested and running on a XP machine, but is it also possible to install these (or other types of ) library`s on the CE5.0 runtime of the MP377 panel?
I have tried to install sqlite on a panel, Siemens have removed the cab installer form the CE panels and replaced ist with something else.
At the end we changed to a PC with flex runtime.
Hello ! Can somebody help me with report of production in winccflex 2008. Now I can see and can print only last cycles of production, and I want...
2,719
Hello everyone, I was wondering if it is posible to communicate an S7-1200CPU with a WinccFlex runtime (running on a PC) via Internet. I don't...
3,424
Hello! I have problem with screen in winccflex 2005&2008. When start runtime start screen is normal,but when go to the other screen and back to...
3,020
Hi there! I have a problem with StartProgram command in Flex. I made an application in Borland C++ builder what works with files from the current...
1,989
Hi, I want to create following function. an analog value is logged into log "Today" each day the log "today" should be copied to log "Yesterday"...
1,432
