WinCCFlexRT OPC server connection problem
idell
Nov 2009
Bucharest
97
hi people! need some help
I want to create an WinCCFlexRT OPC Server, and OPC Client(computers are conected through ethernet). I've created a project with OPC Server option, and try to create OPC connection to other computer but can't find the OPC server, pls help with some advices.
Actually, WinCC Flex RT as an OPC Server is an available option.
When you compile the WinCC Flex RT with "Function as OPC Server" selected under the Device Settings, a message appears "Info: Required license: WinCC flexible /OPC-Server for PC-RT".
The other problem is to configure DCOM between the two computers. Never tried it but have heard that it is non-trivial. Search for "DCOM" and you will get useful information.
Here is how you can set your DCOM permissions properly. Depending on your current operating system, select a document from the list below:
Configuring COM/DCOM for Windows NT or 2000
http://www.matrikonopc.com/downloads/613/whitepapers/index.aspx
Configuring COM/DCOM for Windows XP or 2003 (no service packs)
http://www.matrikonopc.com/downloads/612/whitepapers/index.aspx
Configuring COM/DCOM for Windows XP SP2 or 2003 SP1
http://www.matrikonopc.com/downloads/172/whitepapers/index.aspx
Let me know if you have any questions.
Wassim Daoud
Global Solutions Architect
Wassim Daoud
thanks for links, I've followed the steps described in Configuring COM/DCOM for Windows XP SP2 (my OS is WinXP SP3), also without successes, I also tried suggestions of FAQ from support siemens site, now don't know what to do more.
Hi there! I cannot print report with PrintAlarm option, i put on report one printAlarm and choose needed classes (i can see these alarms in the...
1,351
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
235
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
132
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
183
