Winder Program
jimlee20
Oct 2014
Oregon
I looked through a lot of posts to see if I can find what I am looking for and was unable to find it.
I have a CompactLogix L18ERM, two Kinetix 350 drives and 2 Allen Bradley servos. I am just looking for some sample code to get me started on the winder and traverse servos geared together so that I can wind small wire onto a shaft. My dimensions: Wire is .04", shaft is 1/16", width can be .5", 1" or 1.5", with 13 layers. They also want this to go as high as 2,000rpm. Not sure if I will be able to run that high or not. My biggest concern is running the traverse back and forth that fast and still maintain a smooth winding. I have no problem writing code or tuning the drives, etc. I am pressed for time and if someone has done something like this before it would be a big. help.
I noticed a post from Jeff who stated he did a winder and to search for his name and winder code you can find it. I didn't find the code.
I am not worried about the wire tension in the code. A separate third party machine is doing that, I just have to send it the parameters.
Thanks,
Jim
Lancie1,
Thanks. I looked int he downloads section and did not immediately see anything that would help.
Hi , I Need to write a Logic for Diameter Calculation using estimated method and control of speed for Winder application . Please share if you...
2,750
I've never done this before but it seems like something that will have been done a thousand times in the past. Centre winder is currently manually...
24
3,843
Hi All… I work for a company that makes bags. Operators of the machines that make the bags need to take the bags from a cardboard box that the...
1,796
Hi all, I have to program a machine with an unwinder and a winder. Currently I have 3 VFD Powerflex 527. I need your experience about this topic...
40
11,389
Hello All Working on a large Unwinder/Winder Application Core = 24" Max Roll = 192" Motor is 1780 RPM coupled to 124.41 Gearbox with Encoder...
1,875
