Windows XP pro for embedded system Oem software
Mahir77
Feb 2018
Hayward ca
Hi and hope all is well.
We are starting up a used machine that came from France. We installed 480 delta to 400 vac wye transformer. When we started the machine, the (touch) screen opened with 6 identical split screens. It also had a line running vertically in the middle of the screen.The screen model is pt-150. I need help with this issue any experience? Suggestions?
Welcome to the PLCTalk Forum community !
Unfortunately, "PT-150" does not jump out at me as a touchscreen model I'm familiar with.
Is the PC built into the screen, or is it separate ?
Does the PC run on 24V DC, or does it have a direct AC power input ?
This sounds to me like a video driver board failure. Sometimes they are just caused by loose cables or connectors (especially when a machine is shipped), so you may simply need to power down and disassemble the screen and computer to be sure everything is solidly in place.
Thank u so much. This is where I stuck no info. Only I read under screen pt-150 it is look customized. This point I will use other screen try to go safe mode and check screen setting. After I will follow your suggestions
Tank u again
The screen has 220 v plug is already in the panel power supply is 12 vdc. Pc build in the touch screen
Yes this is it I try put external screen and try to go safe mode didn’t respond. I will disassembled unit Monday to check anything loose thank you so much if it doesn’t work I will contact with them
pic of screens
Never used that model, but it might be something in windows like a bad graphics driver or maybe even something simple like the wrong resolution selected
Can you post a picture of the back of the screen? Perhaps it has a label on it that we can use to identify it
I need to build a VM and looking to purchase Windows 7 64 Pro SP1. Where is a good place to purchase a legitimate copy? I see on Microsoft...
3,463
Hello Will Allen Bradely RS 5000 run on Microsoft Windows 10 PRO
2,894
Hello I hope this doesn't count as advertising. In my search for a solution that doesn't involve virtualization I've stumbled across the plcs.net...
14,324
I use to connect USB to config a 525 VFD:smas: and now with windows 10 I can't anymore why? desktop which is windows 7 connects right away... but...
8,168
Hi all So i recently moved to a windows 10 laptop and installed Unity Pro 11 and all seems to be working correctly, except for the USB connection...
11,425
