Hi all
So i recently moved to a windows 10 laptop and installed Unity Pro 11 and all seems to be working correctly, except for the USB connection
From experience I know that the USB driver can problematic regardless the OS, normally I will have to replug the USB cable two or three times before it makes a successful connection.
On windows 10 is is just staying in a fault state, it shows that there is a Telemecanique BMX CPU connected with an error, attempting to update the driver just states it found the correct drivers but failed to install it.
Now that error is nothing new, the error is exactly the same when my windows 7 machine doesn't successfully connect to the PLC, but like I stated, unplugging and replugging in a few times will eventually connect correctly, but normally it will connect on first attempt.
I've run out of things to try, I've tried all the USB ports numerous times, I've tried uninstalling the driver in device manager and retrying, I even went as far as formatting my machine to ensure I didn't cause some odd driver conflict, but nothing has worked.
I contacted one of the Schneider PLC techs and he states he struggled a bit and then it just came right but wasn't sure why he had the issue or what really resolved it, and he tried basically the same as I did.
I've emailed Schneider Tech support in hope that I can get a response, but they will take a few days most likely.
I'm hoping someone here would have run into a similar issue and managed to resolve it.
