winn cc 6.0 and TP177A
goko2rock
Mar 2011
kerala
26
DEAR ALL,
I habe a problem with connecting wincc 6.0 and tp177a. i need to upload the back from T177A , make some changes and download it back. i configured TP177A configuration:
adress=1
channel,-mpi.
baud 187.5kbps.
plc, s7 300, 313c.
adress=2
my pg/pc interface set to MPI .with same baud
i am able to connect to plc but not HMI.
MY PC ADAPTER USB MODEL:6ES7972-0CB20-0XA0.
do i have to use prosave or wincc flexble?.
should i connect to HMI alone. i tried this also.:(
please help.!
Regards,
Gokul
No WinCC v6.0 cannot be used with a Simatic Panel such as TP177A. The software for Simatic Panels is called WinCC Flexible, or WinCC v11.
Apart from that, an upload of the full program from a Simatic Panel requires some steps to be done by the original programmer, steps that are almost never done.
And, the upload of the full program is not possible with a TP177A panel at all ! This feature is only supported by bigger panels.
Hi All I have winn cc v1.3.1.0 SP1 and i am trying to open a project that was created with ver 1.3 sp2. Is there a way to save the existing...
1,282
I want use a memory bit in seimens like in allen bradley I use B3:0. what is the correct way to address a memory bit in step7 micro winn32
2,025
Hi All, i have a problem with a couple of Simatic touch screens that runs Winn AC MP integrated with Winn CC for graphics control. If we select...
1,409
Hi, When installing the WinCC flexible upgrade from 2005 to 2008, there is always an error when installation the Microsoft SQL server software. At...
6,885
hi guys i need help in how to generate report in ms excel automatically using wincc 6.0............. i came to know it is possible with the vb...
1,437
