WinnCc question
panthripu
Mar 2004
228
In wincc server client configuration with redundant server, if the primary/master server fails and the standby does not takeover. How to switchover clients to the secondary server?
The code below is all in one script called by the main screen. I have 2 buttons. Move record forward and move Record Previous. What i need to do...
3,785
On the HMI-1200, the Wall clock date shows "1/4/1970". How can I correct this? Can't seem to find where this date is coming from or how to change...
910
I have an odd situation where I turn on a valve on the HMI, and the output in the PLC is on and indicates ON in the output map. But the actual...
1,831
We are trying to trend data between 2 separate systems. They do currently share some information between pics (Siemens 400s). Is there a way to...
1,131
Hello I have a project for which I need to convert Protool to WinCC for an upgrade. I have WinnCC Flex SP2 but its the Standard version and I...
3,641
