Wonderware 10.1 Historical Trend Log Interval
Phrog30
Dec 2006
Montgomery, Alabama
1,048
I'm not used to Wonderware, and I can't seem to see where I can setup how often tag(s) are logged. For testing, I have two analog tags setup to log data. I have historical logging enabled and set to keep files for 30 days, which is what the customer wants. However, they are not sure how often they want each point logged. For starters I was going to use one second. However, I don't see where this is setup at. On the 16-pen trend I can see where to configure the update time, but on a historical trend, which is what I am using (8-pen trend), there is no place to select this.
I have setup HTUpdateToCurrentTime within the trend window script to update once a second. However, this doesn't affect the data logging, does it?
Can you Wonderware gurus please point me in the right direction?
Thanks,
James
As far as I know, Wonderware logs historical data if, and only if, the data in question changes. So there is no need for time-based logging settings.
The HTUpdateToCurrentTime only affects the trend you give it, not the data.
@bjh: That was my thought as well, and if I remember corectly, you could set the change percentage for a log entry. I don't recall if there is any heartbeat logging at all, but I haven't used InTouch since version 7.
I agree, ive just had a look but dont think you can change the sample rate, only the way it is displayed.
LH
Use the 'Log Deadband' tag parameter
The 'Log Deadband' sets a threshold that must be exceeded before the tag’s value is written to the log file. You can find this parameter as part of the analogue tag parameter in the 'Tagname Dictionary' in InTouch.
See image attached.
Thanks,
James
You can adjust poll timing in your IO Server software, but not in the Historical Trending application.
See image attached.
Be careful leaving deadband set to "0"on "I/O Real" tags.
If you leave at "0", it will almost continually log because of the decimal places.
So..... if 2 decimal places is all you need, then set deadband at 0.01.
This can help quite a bit on size of log file for the day.
Phrog? What do you mean you were not up every night for the last 7 years waiting for a reply.....
People really need to look at the dates posted before replying to something. haha
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,865
Hi, I am new to wonderware, I am having a question that is it possible that wonderware Historical trend can provide six month trend? I am having...
3,356
Hello folks, Under our current bleach plant wonderware HMI program there's a bunch of historical trends as well as real time trends. What I need...
14,258
I am using Historical Trends please refer the attached image. I described the slider as s1, s2, s3, s4. I need to view only the selected pen in...
1,249
Hi, I just ran into an issue where the InTouch historical trending is not functioning properly, and when I look in task manager, the historical...
3,707
