Wonderware Archestra FSGateway
Volvagia720
Oct 2012
Minnesota
Windows Server 2003 SP2
ArchestrA System Management console 0027.0021.0000.0000
Whenever I try to add any object to the ArchestrA.FSGateway.2 Configuration it acts like nothing happens. (Note: the choices are NOT greyed out) by nothing happens, I mean I see nothing happening or adding after i click on any of the objects to add (Add In Touch Object, Add OPC Object, etc) the right click box disappears and no new object is created.
After doing this, I look into the log box. I get some errors every time I try. Attached is the log of the problem.
I have tried this with both FSGateway versions that can be downloaded from wonderware (2 and 3). I have tried rebooting the computer after every action in instillation and un-installation.
What is going on? What am I doing wrong?
Additional Information: I cannot delete the OPC that exists there. I get simmilar errors except with "deletechild" instead of "addchild" and the line numbers are different.
This does seem odd,
I would suggest posting this on the Wonderware Developers Network or contacting you local wonderware support
Rheinhardt
Answer: There is a file under C:\Documents and Settings\All Users\Application Data\Wonderware\DAServer\FSGATEWAY (or so) called FSGateway.AAcfg. For whatever reason it got tagged as read only. It must not be read only.
(for possible future searches to this thread I've included the following text: From msxml4.dll. Access is denied.
. Access is denied. caught at line 1787 in IOSrvCfgPersist.cpp (in .\).
Hi All I'm a novice starting to work on WW and Archestra, I've been adding repetitive attributes on the front end which has been tedious and was...
2,107
Hey I was needing help with some alarm scripting in Woderware System Platform. What would be the best way to write a script to auto acknowledge...
2,559
I am trying to create a script in an Archestra graphic that will eventually talk to an Omron PLC. I need to access the elements that I create for...
1,624
The application is not getting deployed after a power failure. After the power got restored, I tried to deploy an updated instance but the...
4,054
I have to work on a Wonderware HMI and have very little experience with it. The basic idea is to copy an old project, make a few edits, and load...
4,937
