Wonderware DAServer on Virtural Machine
PLBoudette
Jan 2006
Albany, NY
41
Has anyone tried accessing remotely to a DA server on a virtual machine?
For instance:
PC 1 - Main PC running Windows 8. VM using VMWare Player running WindowsXP. VM has Wonderware application with DAServer connected to PLC via network.
PC 2 - Wonderware application on network trying to access DAServer on VM via Access Name-->Node Name-->IP address of server.
My example is much more complicated (long story) but basically I'm wondering if you can access the DAServer on a VM and if so, how?
I just did this exact same thing yesterday, so yes you can.
The first thing I would check is to make sure your PC2 on your "network" can communicate with your VM.
Is your VM set to "bridge mode" so it acts as if it's connected to the same network your Host machine is on? That will likely be the simplest thing to do. Make sure if you set a static IP in your VM that you don't mess with anything on your main network.
I hope that makes sense. Throw more details' at me and I'll throw a more detailed solution back to you.
The same way you would on a physical server /PC. The application and OS does not know it's on a VM.
You can write your app to detect if it's running in a VM for licensing purposes but very few people do it and I don't think WW is one of them.
xCOMMANDOx, that did it. Changed VM to "bridged mode", reconfigured IP addresses appropriately, and she started humming. Thanks so much for the help.
No problem! At my work we have our networking setup so that we all have our own private third octet, so we can maintain our own network.
EX: 10.20.X.Y
Where "X" is individually assigned to persons within our company and Y whatever I set my machines to.
Host machine - 10.20.129.1
VM1 - 10.20.129.2
VM2 - 10.20.129.3
VM3 - 10.20.129.4
etc.
All bridged with 255.255.0.0 subnet. I have a nice excel sheet with all of my VM names IP addresses, OS, software versions installed etc etc.
EX: 10.20.X.Y
VM1 - 10.20.129.2
VM2 - 10.20.129.3
VM3 - 10.20.129.4
etc.
Do you have an example of it you could share? I am trying to do the same thing for virtual machine. The network guy gave us much of nothing. My email is [email protected]
Having a Issue at a site where WOnderware can seemingly connect to the PLC and all shows good except its locked into a loop for downloading the...
1,806
I am trying to break the link between a wonderware tag and a tag in RSLogix. No matter what i do to the tag in the PLC the wonderware is holding...
1,774
Hi, I have a Legacy project that I have converted from Intouch 7.1 to intouch 11.1 now running on windows 10. I have also uprevved the DA Server...
3,578
Hi all wonderware users As I'm new to this and cant find a solution for the error message STS=1E I'm using a Intouch v10.5 connectet to...
3,528
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,414
