Wonderware DASMBTCP Modbus TCP Device ID
fredbear
Nov 2005
Vancouver
88
So I am trying to access data from an Eaton PXG900 Power gateway with Wonderware. The gateway can be polled for data by Modscan and does provide valid data provided I have the correct Device Id configured in the appropriate field, but I am having trouble figuring out the correct syntax for addressing the gateway's sub-devices, using what Modscan calls 'Device ID', from Wonderware through the DASMBTCP IO server, which works well for all the other devices on this network. There simply is no field that corresponds with 'Device Id' in the DASMBTCP configuration window. The device I am trying to get data from is an Eaton ATS controller connected to the Eaton Gateway via a RS-485 modbus RTU connection. All of that seems to be working well, the problem is in accessing the data with Wonderware in the same way that Modscan does without any issues.
Cheers, thanks, yes I was wondering if I had to use the Modbus Bridge, which may work, but was hoping that there was some funky syntax you could place in the regular PLC object IP addrerss field. Something like 10.10.10.24, DeviceID or 10.10.10.24: DeviceID.
While I have tried a bunch of things already, I am now convinced that something might have worked if not for the dozens of polling of data that results in exception errors. Unfortunately I'm no longer on site so I'm trying to research what the correct configuration is likely to be so there's not too much time wasted in experimenting when I return.
Hi All, I've got 3 Nanodac controllers that I'm wanting to get the data off and on to our InSQL server ,now in theory they have Modbus TCP...
1,831
Hello, I am in the process of upgrading a SCADA apllication to a windows 7 PC. The issue that i am running into is that Wondeware does not...
5,608
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
