Wonderware device status not updating
tjaranson
Jul 2019
Cohasset, MN
I have Wonderware 2014 server with two clients connected to an AB ControlLogix PLC. When I make changes with WindowMaker, save the page then "Notify Clients", the changes don't appear until I restart WindowViewer on the clients.
However, after WindowViewer restarts, all the device selects display as "OFF". Is there a way to have these refresh automatically instead of cycling state of each one individually?
Thank you!
Look at the node properties in the InTouch Application Manager on the clients to select how application changes will be implemented via NAD. If you don't want tags to default to a specific state when WindowViewer starts, then set those tags' attributes to make them Memory Retentive.
I was just wondering if anybody had any experience setting comms between Wonderware Web Studio and an Lantronics XPORT-EIP comm card. I’ve...
1,387
So I am trying to access data from an Eaton PXG900 Power gateway with Wonderware. The gateway can be polled for data by Modscan and does provide...
2,889
I migrated to a WSP2023 application. Now when I open a HMI object (for example a valve or motor) the popup is first correctly show as defined ...
52
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
209
