Wonderware - Display Value
alfredob
Jun 2011
Brasil
Hi all, first of all im would like to apologize for my english, is not my native languaje.
I was wondering if someone could help me with this. Im doing a project in archestra ide, and i would like to know if i can show on the graphic of my symbol, the item adress or reference Example: DB1,X4.1. i want to know if that is possible.
And another problem (all of this is on the graphic editor of archestra) how can i open a new window, and close the current window at the same time.
Im Using Archestra Ide 3.1
i´ve attached an image of my problem, would be great if someone could help me, thanks in advance.
nvm problem solved
Hi
I would like to find out if in your solution your a address was specified within the your ArchestrA Object as a String UDA, or did you pull this data from your IOServer?.
We are doing something similar, what was your approach?
Rheinhardt
Is there any way to display a something other than the tag name for the pen label? For example, my tag is "IP087_Level" and I want to display...
1,174
Hello, I am using Scadapack 357 controller and Trimble Acutime 2000 GPS. I have to show the position of the GPS from the controller to the...
1,855
I am new to Wonderware and am trying to display a few columns of information from an SQL database onto one of my HMI screens. The SQL database...
3,366
Hi Guys, I am trying to do a multi-monitor intouch application. I have two monitors in extended display. I already configured the ini.file and...
3,120
Hello, Im trying to implement the custom view i can make in insight explorer in my wonderware HMI system, which is ran from a normal PC. I can...
8,151
