Wonderware Historical Trends
kudave88
Apr 2007
California
I am trying to come up with a way to add pens to a trend other than the standard "click the trend to display the trend setup, click the pen to display tag window" method. There 500+ tags that are possible pens so operators don't want to do that.
Two options I've looked into are:
1. use the "Filter" feature at the bottom of the tag window to filter based on areas of the plant in the tag comments (cons: most tags don't have an "area" in their comments section/would have to modify tags)
2. add a "change pen1" button that would show a window (one window for each area of the plant) that include buttons for each tag and HTSetPenName script behind it. (cons: adding 500+ buttons for each tag)
Any other clever ways to add pens and keep operators happy?
Thanks!
I am using Historical Trends please refer the attached image. I described the slider as s1, s2, s3, s4. I need to view only the selected pen in...
1,251
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,883
Hi, I am new to wonderware, I am having a question that is it possible that wonderware Historical trend can provide six month trend? I am having...
3,375
Hi, I just ran into an issue where the InTouch historical trending is not functioning properly, and when I look in task manager, the historical...
3,712
I tried to find some information using the search engine and I couldn't find anything helpful, so I'll post this here. I've been assigned to a...
7,159
