Wonderware Information Server Backup Error
Purrdie
Mar 2011
Las Piñas
34
Hi Guys,
I have a problem in backing up my WIS.
When I try to backup, a popup will appear:
"The Information Server backup/restore operation has encountered an error.
The Wonderware Information Server Cabinet file Creation Failed. Error HRESULT E_FAIL has been returned from a call to a Com component."
That is also the error in the SMC.
below is the backup log file.
5/31/2014 5:00:20 PM Wonderware Information Server version : 5.5.000
5/31/2014 5:00:20 PM Backup Process started....
5/31/2014 5:00:20 PM Creating temporary directory.....
5/31/2014 5:00:20 PM ============================================================
5/31/2014 5:00:20 PM BEGIN: Portal configuration Backup
5/31/2014 5:00:20 PM Backing up Portal Config.....
5/31/2014 5:00:20 PM Backing up color / logo / Home Page url ....
5/31/2014 5:00:20 PM Backup of color / logo / Home Page url is complete.....
5/31/2014 5:00:20 PM Backing up Wonderware Information Server DB.....
5/31/2014 5:00:20 PM Before Wonderware Information Server DB SQLServer Backup
5/31/2014 5:00:21 PM After Wonderware Information Server DB SQLServer Backup
5/31/2014 5:00:21 PM Backup of Wonderware Information Server DB is complete.....
5/31/2014 5:00:21 PM Backing up MTS users.....
5/31/2014 5:00:21 PM Backup of MTS users is complete.....
5/31/2014 5:00:21 PM Backing up Registry and application information.....
5/31/2014 5:00:21 PM Backup of Registry and application information is complete.....
5/31/2014 5:00:21 PM Backup of Portal Config is complete.....
5/31/2014 5:00:21 PM ============================================================
5/31/2014 5:00:21 PM END: Portal backup is complete
5/31/2014 5:00:21 PM BEGIN: Table Weaver Backup
5/31/2014 5:00:21 PM Backing up table weaver.....
5/31/2014 5:00:21 PM Backup of table weaver is complete.....
5/31/2014 5:00:21 PM END: Table Weaver backup is complete
5/31/2014 5:00:21 PM BEGIN: InTouch Backup
5/31/2014 5:00:21 PM Backing up Intouch WindowSets,Symbols.....
5/31/2014 5:00:21 PM Backup of InTouch WindowSets,Symbols is complete.....
5/31/2014 5:00:21 PM END: InTouch backup is complete
5/31/2014 5:00:21 PM BEGIN: Active Factory RWS Backup
5/31/2014 5:00:21 PM Backup of RWS started...
5/31/2014 5:00:21 PM Backing up of RWS tables started ...using credentials from Configuration.Config fileusing user account :sa
5/31/2014 5:00:21 PM Backup of RWS tables complete
5/31/2014 5:00:21 PM Backup of RWS Configuration files started...
5/31/2014 5:00:21 PM Backup of RWS Configuration files complete
5/31/2014 5:00:21 PM Backup of RWS output files started...
5/31/2014 5:00:21 PM Backup of RWS output files complete
5/31/2014 5:00:21 PM Backup up of RWS system tables started ...
5/31/2014 5:00:21 PM Backup of RWS system tables complete
5/31/2014 5:00:21 PM Backup of RWS complete
5/31/2014 5:00:21 PM END: Active Factory RWS backup is complete
5/31/2014 5:00:21 PM BEGIN: ArchestrA Graphic Backup
5/31/2014 5:00:21 PM Backing up ArchestrA Graphics.....
5/31/2014 5:00:21 PM Backup of ArchestrA Graphics is complete.....
5/31/2014 5:00:21 PM END: ArchestrA Graphic backup is complete
5/31/2014 5:00:21 PM Creating the .Cab file. This process may take few minutes...
5/31/2014 5:00:21 PM Backup Process Failed....
This is a known issue that has not been addressed yet. Go to where you want to save your backup and create the file manually with notepad, using the same name that you want your backup to be, ie InformationServerBackup061219.CAB
When you go to do your backup, choose that file and everything should work correctly.
Steven
After many false starts, networking problems, crashes and calls into Wonderware......our Web Information Server is up and running. Its not...
8,793
Hi, I installed and configurated Wonderware Information Server on Windows Serwer 2003 R2. I installed winXMLExorted and exported my inTouch...
1,687
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
155
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
184
