Wonderware Intouch 7.11 to Wonderware 2014
Nov 2008
Indianapolis
152
I am going to upgrade a legacy 7.11 project to Wonderware 2014.
I already bought the license from Wonderware North.
I was just wondering if anyone had any tips for me.
I have only had a little exposure to Wonderware in the distant past.
I chose 2014, because I am installing my runtime on a Windows 7 PC. It previously was 7.11 on a Windows XP PC.
Wonderware north will give you a temp license if you need to do 9.? first.
I think it will work. You can copy the original 7.11 somewhere else and test. If it fails, you still have a copy of the 7.11 to use.
I had pretty good luck with 7.11 to Intouch 1012.
As long as "Doc Viewer" add-in is not installed. Then you have to remove that window to make it work.
Let me know and I can tell you how to remove a window from Intouch.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
162
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
416
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
189
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
483
