Wonderware InTouch - Auto select application
blue39
Guest
B
In InTouch (7.0 / 7.1) you normally use the Application Manager to select which InTouch Application is used by Draw / View.
I need to select between 3 different apps right after the computer is booted and then run View.
Can't find any registery entries that point to which app it to be used. Ditto for an .INI files.
Anyone know where the info is kept ?
Yep - take a look at your win.ini file (c:\windows)
There should be an Intouch section where you can modify the ApplicationDirectory.
-Trevor
Yep, that's it - Thanks ! Forgot that some programs use that .ini and also just for others, there are other .ini files in the Windows dir.
You can also use...
"C:\Program Files\Wonderware\InTouch\view.exe" C:\IntouchFolderName Actually the above is the path for 8.0 and higher. 7.X uses something like C:\Program Files\FactorySuite\Intouch.
wonderware intouch installation
hi everybody,
I try to install wonderware intouch 10.0,
it says I should install .net framework 2.0 manually before install wonderware, but it doesnt realize I have net framework on my pc.have anyone had the same problem? I cant install intouch..
thank you
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
178
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
178
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
450
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
212
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
496
