Wonderware Intouch- MS Access
JIVM1127
May 2018
Mexico
20
Hi everyone, I have a project that demands Wonderware to communicate with MS Access, to establish connection I have followed this very useful but bit outdated link:
https://www.logic-control.com/datasheets/1/Tech%20Notes/Tech%20Note%20154%20-%20Config%20InTouch%20to%20Query%20Data%20from%20SQL.pdf
My problem is whenever I try to retrieve data from the Access table, using SQLSelect only returns -1,
Seeing the manual above it says that the structure is:
ReturnCode = SQLSelect( ConnectionId, TableName, BindList, WhereExpr, OrderByExpr );
Right now my code looks something like this:
SLQ_Search_Ton=SQLSelect (ConnectionID, "tabletest1", "Register_DB", "type=Item1", "Ton LAST" );
where Register_DB is my Bindlist, Item1 the row name and Ton the column name.
Is this right?, I have seen some Technotes but I have to admit I just dont get it.
https://softwaresupportsp.schneider-electric.com/#/okmimarticle/docid/tn1284
Any help will be very appreciated.
Thanks in advance!
Thank you for your answer, I have to say that I dont really know how to solve it, when I put
I think you type=Item1 should be type='Item1' with a single quote as per SQL strings.
Now appears the message "string cannot mix with another type"
Dont know what does that mean, since there is no discrete variable in there, what do you guys think could be the solution?
Could be that I cant call the action script from a push button? must be a condition script or something like that?
Thanks again!
Thank you all of you guys, I have to say that after trying a lot I wasnt able to figure out a way in which we can retrieve values from Access, dont really know whats wrong about the code.
But using Excel with the WWPoke and WWRequest it is right now our way to get out of the deal, meanwhile going to try to solve this.
Thanks a lot for helping me out!
We have 10nos client wonderware intouch 10.5 running on windows7 32bit pc. They take program and status from windows 2008r2 Servers. One of the...
2,863
I have a wonderware standalone HMI collecting process data from our production line. I am writing those values to a database in MySQL, though I...
2,746
Hi, I would like to know as how to get the data of some of the parameters such as temperature/ pressure/ date/ time created in wonderware intouch...
8,432
Hello, I have an InTouch Wonderware question about setting security access of someone going into development (WindowMaker) I can set access on...
6,168
I was doing some changes to an InTouch project when I realized I had done a mistake that I couldn't undo. So I restore a backup I had of my...
9,678
