Wonderware popups disappear
PLBoudette
Jan 2006
Albany, NY
41
I have two computers in two different locations running the same Wonderware 11.0 program. The problem I am having is certain popup windows on the one computer will disappear almost immediately after opening them. I do not experience this issue on the other one. I checked the "Action" script on both and they are the same. Anyone else seen or heard of something like this happening? Thanks.
If I'm not mistaken, Pop-up windows will close if their display space is encroached upon by a "Replace" window. I saw this happen once in an InTouch application after it was scaled to a new graphics resolution. The Pop-up window was intended to sit just above the Replace window, but they intersected after the graphics resolution conversion. I had to resize and reposition the Pop-up window in order to correct the problem.
The Windows operating system is Windows 7 Professional 64 bit. The Wonderware version is 11.0.04001 2119.0801.0202.0007. It's strange because it's only certain popup windows that this will happen to. Some will close immediately. Others will pop up and stay like normal. Any help is appreciated. Thanks.
I agree with Bit_Bucket_07. I would check the location of where the pop ups are opening that close right away compared to the ones that will stay open.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
162
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
110
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
193
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
186
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
169
