Wonderware slow startup with Windows 7 Pro
Apr 2011
Manila, Philippines
295
Hi Guys,
We are currently experiencing slow startup of Intouch 10.1.2 Windowmaker/Windowviewer. We are running with Windows 7 Professional SP 1.
It took about 4-5mins before the logo appears after choosing an application in application manager and then; another 5-8 mins for the Windowmaker / Windowviewer to initialize.
Do we have to check some settings within Windows?
Thanks and Regards,
Fher Vryle Sestoso
factors to consider
pc speed, memory, hard drive size.
what else is trying to load and run? virus software running will kill performance.
there are several viruses that do nothing but run and eat up cpu speed. you might have one of those.
regards,
james
I would also look at all Windows application logs, if you have anti-virus ensure the wonderware anti-virus exclusions are done. You can also find a checklist on the WDN website to check your system setup.
Good luck
What type of application is it?
Stand-alone? NAD?
I've found that if I have network problems and the application cannot connect to the server for the project (if NAD) or if it can't connect to the DAServer (assuming that software is on another piece of hardware), the system will hang and take a long time to load. Once it does, I see I have comm errors.
Maybe network related.
Migrated a PLC-5 to Logix yesterday. The new Logix communicates via Ethernet but there is still another PLC-5 communicating via ControlNet...
31
10,473
Hi , i am converting a standalone app to a modern app with many archestra grapchics replacing the old classic ones.. . The thing is that each time...
2,206
Hi guys, I'm working on a Water treament plant application in wonderware 9.5 and using DASABCIP v4.0 as the server. It is connected to a...
29
21,402
Hello and welcome to intouch people, These days I am having problem with fetching trends in Intouch very slow...I don't know where to...
8,843
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
