I have an application where Intouch needs to send a couple values to Excel, where a unique row will be found. By using a SQL command, 3 other values in the row will be read and assigned back to Intouch tags.
The problem I've had is that something keeps the data from being read. The problem seems to be the format of the Excel file. If the bind list is configured to read just 1 of the values, then sometimes it will work. But, adding 1 or 2 more values causes it to fail. Another file with the same exact column headings may not work at all. I've set the Excel files involved to either "text" or "number" depending on the Intouch tag they are tied to. I was told by the local dist. to use a 32 bit version of the ODBC manager. The DSN seems to be limited to Excel 97-2003 version.
Documentation and examples for this seems to be very weak. Even the local distributor doesn't seem too interested.
I feel like I'm very close to making this work but if I can't get a file to work in a predictable manner, its useless.
BTW, there is no possibility of getting away from Excel. This is a QS, quality controlled file and they want to get their data from it.
TIA.
TIA.
