Wonderware user input question...
jimdi4
Aug 2004
108
Hello,
I am using wonderware Intouch Window maker 9.0 and I am setting up screens for PID loops.
Specifically the PLC is a Modicon that I programmed with Concept. I utilized the PID1 block and through Wonderware I want to be able to change the P-I-D values.
There is no problem with the P value Proportional (Reset) its a REAL number. So i was able to utilize the analog Tagname wizard...
The I (integral) and D (derivative) values are in TIME values in the PLC. So in wonderware I cannot use the analog tag wizard for the I and D values.
I tried the TouchLink > User Inputs > Discrete but I don't get a keypad or a input popup....
Anyone experience the same issue? Whats the best way to get around this?
Thanks In advance :D
Sure the units of these are in time, but the PLC registers should be of real type as well. At least that is the way it is in AB world.
Just be careful that you limit the HMI to only input valid values - you wouldn't want to fault the processor by inputting invalid values.
I specifically stated I was using a Modicon Not an Allen Bradley PLC..
I know AB uses real data for the PID paramters but Modicon doesn't. The P is a real value but the I and D are time variables that are not the same as a real value.... :cool:
Well I hope you figured this out by now. lol
You need to make a real tag to enter the value in wonderware. Then in the plc use a real_to_time block to make the conversion.
Hi, I'm designing an HMI using the Wonderware Archestra IDE (2017) and I'm trying to figure out the best way to use a user input to pass a value...
2,653
Hi All, I would like to log an activity of several buttons, value changes etc. to a txt file. Writing to a txt is not an issue but I am not sure...
1,015
I have generally not been required to implement security in InTouch applications, so if there has ever been a need, then have used the InTouch...
2,893
I am using Wonderware InTouch 8.1 Is there a way to get a list of existing User Groups in and populate a combo box with it? There is a...
2,596
Hi all, I have a question about Wonderware SP 2012. Want to log all the user access on the machine, but don't know if it's a Historian process...
2,424
