Wonderware Intouch Get List of User Groups
theColonel26
Feb 2014
West Michigan
785
I am using Wonderware InTouch 8.1
Is there a way to get a list of existing User Groups in and populate a combo box with it?
There is a $GetUserNames() function but nothing for Groups
Is there any workaround?
If this is classic InTouch, which with V8.1 it most likely is, then do the best of my knowledge there is no user groups, just priorities.
You could roll yr own user groups I guess
Isn't InTouch basically Indusoft Web Studio?
See this answer http://www.indusoft.com/Support/Forums/aft/648
It sort of is now, branded as InTouchMachineWdition (ITME), but classic InTouch still remains.
This is Machine Edition.
There are user groups. You can set an access level range for each group. But there is no way to list the groups at runtime.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
158
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
412
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
187
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
481
