Wonderware - Windows 10
DonkeyOaty
Jul 2016
Newcastle
I'm busy porting legacy windows XP apps to Windows 10.
Wonderware claims Win10 support, but I have an issue that I cannot find a response to anywhere. It is looking for the comms driver apps in the wrong directory. It's looking in /Program Files/ rather than /Program Files (x86)/ , but I can't find anywhere to redirect this.
Can anyone give me a clue?
Hi DonkeyOaty,
I'll disclaimer this by saying that I am not a tech support agent. But being a Wonderware PacWest employee, I may be able to provide you some guidance.
I'm going to assume that by "Wonderware" you mean InTouch, or based on the image you provided, the Data Acquisition server for Allen Bradley.
What version of InTouch are you using? Only the most recent 2014 R2 with Service Pack 1 release is supported on Windows 10. So if you are not running the latest release, that could be your initial problem. (This page offers some limited information on what are the latest release versions: https://wonderwarepacwest.com/support/product-versions/, additional information can be found on the Schneider Electric Global Support website here: http://softwaresupport.schneider-electric.com/)
Also, depending on the version of DASABCIP you are running, such as if it is an older driver, that may not be supported on Windows 10 either. Wonderware released a new set of device integration drivers called Operations Integration, these are next generation updates providing enhanced features over the previous DA (Data Acquisition) drivers.
I would also recommend reaching out to your local Wonderware Distributor, based on your location that would be Wonderware UK (http://wonderware.co.uk/). You may have a Support Agreement, or at least a local System Consultant who might be able to offer some greater advice.
If you have any other questions, I'll do my best to answer them or at least point you in the right direction.
Regards,
Jeremy
Is DASABCIP installed and configured correctly "System Management Console" (SMC), and is the SMC server activated?
If you do not see DASABCIP in the DAServer Manager and you have installed it, you may have to run the "Change Network Account" utility.
So, a WW PC's hard drive decided to go bunk. The local tech did use Windows 7 Back and Restore to save an image. However, the restored image...
1,019
Hey guys, I've got a bit of a conundrum that I'm trying to solve. I'll say what it is basically, and then give the explanation of the greater...
7,738
Hi! Does anyone know if Wonderware 10.1 will run on Windows 7 or Windows 10 x64? I have an aging installation currently running on Windows XP and...
1,744
Several years ago, I created two WW apps. The machines were similar, but not exactly the same. Both machines are controlled by a single PLC...
1,945
Hi Guys, We are currently experiencing slow startup of Intouch 10.1.2 Windowmaker/Windowviewer. We are running with Windows 7 Professional SP 1...
4,169
