marwan_13
Hi all Siemens Expert..!
I’m currently working on an interface communication with a Siemens S7-313, connected via Ethernet.
Here is a list of the configuration made in the project:
PLC:
S7-313-2DP
CP Card 343-1EX11-0XE0 (IP: 192.168.0.2 subnet 255.255.255.0)
Server:
WinXP Server 64 Bit , firewall off.
IP : 192.168.0.98, subnet 255.255.255.0
Network card is setup accordingly.
I’m able to ping the PLC, all 4 32 bytes packets coming back under 1ms.
Archestra:
SMC Version
DASSIDirect2
Under that branch, I have a node called S7300, with the port type “S7Cp”
The parameters at this node are the following:
-Processor type : S7 PLC
-IP: 192.168.0.2(The address of the S7 controller)
-Local TSAP : 1.0
-Remote TSAP : Rack No.: 0 -- Remote Slot No.: 3 -- Connection Resource : 3
-PLC Connectivity activated, frequency equals to 60 sec.
-Reply timeout : 15000ms
-connection timeout: 30000ms
-Alarms & events disabled.
Now for the device group:
-Name is “Master_PLC”
-Poke mode : Full optimization
Wonderware:
InTouch Window Maker Version 10.5
-Access name : Master_PLC
-Access : Master_PLC
-Node name : none
-Application Name : DASSIDirect
-Topic name : Master_PLC
-Protocal : Suite Link
-Advise only active items
-Secondary source disabled
Shall I need to configure CP card communication in siemens to work?
Regards,
Marwan
PLC:
S7-313-2DP
Server:
Archestra:
SMC Version
DASSIDirect2
-Local TSAP : 1.0
Wonderware:
-Node name : none
Regards,
Marwan
