Wood drill and conveyor
I feel I can write some of the basic input /outputs for RLY logic, but then it gets trickier for me with all of the other available ways available.
I was starting to write the ladder logic program and got stuck after a three rungs. Geez.
Here's my sequence / thoughts.
At the main panel will be an ON/OFF PB station
It will upon
ON:
Power up Hydraulic Motor ( HM )
Verify or raise Drill Motors( DM )to the up position.
Lower Pneumatic Stops (Pneu Stps )or verify
OFF:
Lower Pneu Stps
Stop conveyor
Stop DM's
Raise DM's to up positionStop HM
At the front of the machine not depicted will be a Start /Stop pb station.
It will:
START
Start DM's
Start conveyor
STOP
Stop conveyor
Stop DM's
Raise DM's to the up position
The JAM whisker LS sill create an ALL STOP
Wood rides on conveyor until the Position LS ( POS LS ) no pun intended LOL
The POS LS now made
PN STPS raise , conveyor stops
DM's lower
Lower DM LS is made signalling drill is at the bottom.
DM's return to up position.
PN STPS lower
Conveyor starts.
The POS LS needs bypassed here right for a short time . Right?
Cycle is repeated.
The Drill Motors return to the up position upon "ON " have me puzzled a little. The LS's available are HOME , UP -right and left motors and DOWN-right and left motors.
If I use the DM's LS's I would have , not considering the HOME LS:
Up Down
1 0
0 1
0 0
Right? It does have a upper "HOME LS " as well.
Hello all i know it isn't a plc question but with time i have seen a lot of knowledge here on motors/drive etc.. When braking with a drive, we...
18
7,718
hello all, we have little side project cooperating with local University. They are reading resistence between two screws screwed into wood (cca...
2,423
Hi, I was trying to inspect teak wood (This one is imported, don't know the exact origin). But it seems that the wood is absorbing Penetrants...
2,276
I have wooden boards I need to pickup with a robot. They are 7" x 25" x 1/8" thick. They weigh only about a 1/2 lb , but they have high and rough...
2,719
HI folks! I'm from the Philippines and I would like to ask who is/are from the same country so that I could confirm if SELLWOOD 2N HMI software...
1,862
