Sensing that a solenoid valve's coil is passing current seems a sensible way to prove that the coil is not "burnt out".
However, just because it is passing current, it doesn't mean that the solenoid valve is opening, which I'm guessing is the real need....
If it is critical to know that the valve has opened, then you need to provide feedback in some form. There really is no other way.
You can use pressure, temperature, or flow, as appropriate in the application.
