Hello,
I have an application working on a TP700 Comfort panel (developped with WinCC Advanced on TIA Portal V11). In this application I am writing values from 5 variables each x second (have to be variable) in a CSV file in a SD Card, and I asked myself "if I write a lot in the SD Card like this, I may have a problem because the SD Card has a maximum write cycle number". I thought about the log modul of WInCC adavanced but I don't understand why we don't have this problem with this modul (if what I think about the maximum write cycle number is true problem with my application)
Second thing, if the WinCC modul is really the soultion, I will have two problem:
- make the logging cycle variable (in the WinCC modul you have to specify 1 second or 2 second, ... and it will not be variable)
- before writing my values I am writing a header (date, customer name, project name, ...) and the modul doesn't allow me to insert any data before the log
Thanks for helping me and sorry for my poor english (you guessed ... I'm French
