CSV file write in TwinCAT
piash.ali
Sep 2017
Germany
19
Hi
I was trying to write a csv in twincad and I used the sample code from beckhoff (https://infosys.beckhoff.com/englis...tml/TcPlcLibUtilities_ARG_TO_CSVFIELD.htm&id=) but it showing error in database .
I was wondering if anyone suggests me a small program.
Thanks!
MAX_CSV_ROWS:UDINT:=100;MAX_CSV_COLUMNS:UDINT:=5;MAX_CSV_FIELD_LENGTH:UDINT:=100;
database : ARRAY[0..MAX_CSV_ROWS, 0..MAX_CSV_COLUMNS ] OF STRING(MAX_CSV_FIELD_LENGTH) := (* Source PLC database *)
'0_0', '0_1', '0_2', '0_3', '0_4', '0_5',
'1_0', '1_1', '1_2', '1_3', '1_4', '1_5',
'2_0', '2_1', '2_2', '2_3', '2_4', '2_5',
'3_0', '3_1', '3_2', '3_3', '3_4', '3_5',
'4_0', '4_1', '4_2', '4_3', '4_4', '4_5',
'5_0', '5_1', '5_2', '5_3', '5_4', '5_5';
END_VAR
Hi Piash,
When I need to write data from a Beckhoff PLC to a CSV file, I use FB_FileOpen/FB_FileWrite/FB_FileClose.
If you need to read from a CSV file, just do the same but use FB_FileRead instead of FB_FileWrite.
At this moment, I do not have a sample program using this function that I can send. But you'll see, those function are pretty easy to use, try it and let me know if needs more help!
Best regards,
Hi Piash,
Best regards,
Thanks for your suggestion. I have fixed the error.
To use this sample program from beckhoff . We have to declare the variable MAX_CSV_COLUMNS, MAX_CSV_ROWS as constant. such as VAR CONSTANT.
for the data we have to use as
['0_0', '0_1', '0_2', '0_3', '0_4', '0_5',
'5_0', '5_1', '5_2', '5_3', '5_4', '5_5';]
then it will work
And you can copy those constants mentioned above from the sample program. I did exactly same mistake when i tried this same sample.
{attribute 'Tc2GvlVarNames'}
VAR_GLOBAL CONSTANT
MAX_CSV_ROWS : UDINT := 100;
MAX_CSV_COLUMNS : UDINT := 100;
MAX_CSV_FIELD_LENGTH : UDINT := 100;
END_VAR
VAR_GLOBAL CONSTANT
END_VAR
Thanks. I already did exactly as your suggestion.
Hello! I have a question about a problem writing to a CSV file via twincat3. From the example code that beckhoff provides, I would like to be able...
1,010
Hello, I have an application working on a TP700 Comfort panel (developped with WinCC Advanced on TIA Portal V11). In this application I am...
1,916
Dear, I want to write data into a txt or csv file. This data contains text and numbers. Later I want to read some of that data into the...
5,257
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
542
Hi Everyone, I am hoping a Red Lion Expert can point me in the right direction. I am experimenting with data logging on a CR3000 10" screen...
608
