WW Historic Data Trending doesnta allow me to activate Historic Trending
Oct 2008
USA
25
we have a working version of historic trending on one project, I'im attempting to apply the same screen to another project. I have $HistoricalLogging = 1; in my application script and i have forcelogging in my ini.
i have an object with a discrete statement that references $historicallogging, i also made the object so on left click it changes the current state of $HistoricalLogging. Nothing seems to latch Historical logging
when i click on the object it does flip momentarily but then returns quite quickly.
This screen has been tested and works properly on other projects.
Thanks in advance!
In your Historical Logging tab under Configure, make sure "Enable Historical Logging" is checked and the log file directory exists.
The Enable Historical Logging from Special>Configure>Historical Logging... is checked.
I have a configuration file in the project folder.
also i have the access name produced i have viewstream and GEHCS up and running.
Ok...I'm guessing you have enough hard disk space as well. The button to toggle $HistoricalLogging, is it set for toggle instead of direct?
I have attempted to toggle it several methods
the Direct control
the Toggle Method
and even the classy $HistoricalLogging = not $HistoricalLogging; method in a mousedown actionscript
I'm wondering if your historical log files are corrupted as well. Have you tried deleting the idx and lgh files and reboot?
[History]
szRetrievalDll=WWNHIST.DLL
szRetrievalParams=D:\Temp
szLoggingDll=WWFILPRO.DLL
szLoggingParams=D:\Temp
szTagProvDll=WWNHIST.DLL
szLoggingNode=
szFailOver=
bLoggingEnabled=1
bUseAppDir=0
[InSQL]
szRetrievalDll=WWINSQL.DLL
szTagProvDll=WWINSQL.DLL
szLoggingNode=
szFailOver=
bLoggingEnabled=1
bUseAppDir=0
No but i will give that(deleting those files) a try tomorrow morning.
I remember seeing an error message early on in the project but didn't capture it.
It does exist.
I also have the save file function pass this statement
{This sets up Directories Locations and charting methods}
HDWDBDir = InfoInTouchAppDir();
HDWDataDir = HTGetLogDirectory();
HDWFilename = "c:\HistoricData Date " + Year +"-"+ Month +"-"+ Day +" Time "+ Time +".csv";
also, deleted the LGH and IDX files and it did not change any function.
When i restarted the program it did not produce any new files.
I restarted the trending on the operational program and the IDX and LGH files were produced. so its definately isolated to this project
Have you tried running the working app on the new pc or vice versa? Maybe a bad or corrupted install? Can you post your app? I'm pretty sure someone can help look at it.
This is the motor nameplate from one of the powder hoist motors on the USS Texas an older generation battle ship, built in 1911-1914 ish. The...
298
I'm doing a routine that will average out a value based on a real-time measurement and create an alarm level X% higher than the value. This...
1,033
Good afternoon. I wanted to know if you could support me with a detail I have with a panel view plus 1250. The problem is the following; There...
1,190
hi friends, In one of my project i am using RSVIEW32 for SCADA, in which i want to record/ monitor some critical instruments datas, anyone please...
1,526
Hello, im quite new and still learning. I would like to ask is it possible for FATEK PLC to read data value more than 16k? I'm trying to move my...
63
