WWIntouch don´t write and don´t read from PLC
Leonardo10
Nov 2006
Rio de Janeiro
Hi All
I have installed my PC, WWIntouch 9.5,RS logix 5,OPC LINK 8,
RS emulate and RSlinx 2.43.
Well, I build a simple ladder in Rslogix 5 and i run RS Emulate 5 putting processor in Online
Everything well until here.I created one topic OPC on RS LINX and too I created some buttons (i/o discrets)on Intouch 9.5.
Problem is that I don´t get read and not write to PLC!
OPCDataControl(SoftwaretoolBox) read and write on PLC pefectly !
Any help will wellcome !
Make sure you select DDE instead of suitelink in your Intouch Access Name configuration. You should be able to make it work without OPCLink by using RSLink as the application name. If you are using OPCLink, I believe you have to have a prefix i, m, d, etc. in front of each item name.
doug2 said:
Just curious why did you buy linx instead of using the free dasabcip ?
Probably so he can use RSLogix to monitor. I'm not sure if any of the IO server from WW will work with RSEmulate. DASABCIP is for the ControlLogix platform.
Your right Ive only used it with clx. Went back to the dasabcip manual and plc5 and slc are only accessable with dasabcip through a clx bridge. sorry for the confussion.
Thanks All
WWIntouch now write and read in PLC 5 emulator. I believe that OPClink don´t was setup to start as service. OPClink is working with Suitelink.
Hello everybody! I have made a FC with SCL, the problem is that don´t work. I have been testing the same code with VBScript and it´s work fine...
2,049
Hello, Using Panelview 1500 Plus panel with RSView ME Studio converted application from Panelview 1200. When I set the screensaver-time at 5...
3,914
46
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
125
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
146
