yasakawa drive problem
jap
May 2009
manila
17
Good day everyone!
May I once again ask for anybody's help in my problem with yaskawa servopack CACR SR BE12M.It is a servo drive with speed control analog voltage (+/-10vdc)input. Feedback signal from this drive output to the controller are line driver and open collector. I used the open collector output from the drive unit to my PLC which is an fx1n-40mt via the high speed inputs x0,x1 for A,B phase. I had no problem running the motor cause I just send analog voltage signal from my special module fx2n-4da to the drive unit and I could also monitor feedback signal via high speed counter c251 when the motor rotates. My problem is the accuracy because there is always a 1 to 2mm shorter than the previous feed..every succeeding feed of the material is shorter from the previous one.
Thanks in advance for any help.
Jap
Dear superiors, When i try to communicate Yasakawa A1000 AC Drive and simense s7-300 plc via profibus the drive shows error bb on its display...
6,912
Hi, I'm new here and getting into plc's. Haven't did much with them since college so doing some refresh. Friend has this rotissery thing he...
1,467
Can any one help me regarding how to give set point via field bus for control yasakawa a1000 drive while it is running on PID operation. Also i...
1,486
Dear all, Im having a difficulty regarding yaskawa a1000 drive running with pid controlling.:utoh::bawling: Im giving 0 to 10V analogue input to...
2,317
hii i have a servo controler mp2300 from Yaskawa. i want to connact with cimplicity hmi through modbus tcp protocol. i open mudbus tcp request...
6,332
