Yaskawa A1000 experts
PLC
Sep 2002
NC
311
I’m working on an application where I would like to mount the
encoder on the end of the gearbox instead of the motor
Can I hear from any of the yaskawa users who have done this and did
you do it using parameters F1-12 and F1-13 ?
Vector mode only
I would think you could but you would not be able to set it as a Flux vector drive
Open loop and V/F should work they don't need the encoder to work
but the real question is why would want to you would lose performance
you could divide the motor counts to get the gear box counts and keep the performance
FYI
Yaskawa tech support said it will work fine
Those F1 values set the ratio ie gearbox
Hi, I want to do an electronic line Shaft with Yaskawa A1000. I think a must update firmware. Do is a user that have a firmware for this? I...
776
Hello friends, I have Yaskawa A1000 drive and I want to activate a safety function during starting a drive .🤾 I have assign frequency...
1,747
Im assisting a customer with a Yaskawa A1000 drive. The machine came from China The part number is CIMR-AB4A0023FBA Can someone help me find the...
2,522
Has anyone ever tried to connect an HMI to a Yaskawa A1000 VFD? If so, what HMI did you use and what communications protocol? I want to try to...
2,076
Hello everyone, I am new to Yaskawa drives and I’m struggling on getting the drive to run the right rpm. My experience with other drives is I can...
20
5,103
