Yaskawa MotionWorks IEC Express Programming
ksu
Jul 2015
Manhattan
I am very new to PLC programming and would like to if there is a way to modify an existing MotionWorks program that uses block diagrams, by modifying the actual code.
I was also wondering if there was a way to rewrite the entire program in structured text instead of block diagrams.
Thanks in advance
Yes, if you have the source code, and it is not locked, then you are free to do anything you want with it. As has been discussed in previous posts, it doesn't make sense to write in only one IEC style when you have all available. Especially if you already have a working project. Better to figure out the other styles, since you will be far ahead in the long run. It isn't that difficult. It is a different way of thinking, but once you get it, it will clear where the advantages are.
I'm self teaching myself Yaskawa's IEC MotionWorks to make some changes to an existing machine we have. The original programming was done by an...
2,191
Can anyone confirm if the following capabilities exist for Yaskawa MotionWorks IEC / MPiec controllers: - Indirect addressing of variables -...
6,811
Hi all, I converted a project from MW+ Express to MW+ Pro, for the benefit of more percise control over the performance of different parts in...
1,870
I have a spin welding machine utilizing a Yaskawa Sigma II motor, with an MP940 controller. I am attempting to change the weld characteristics...
33
9,640
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
125
