Dear All
I am suppose to make some changes in existing Yokogawa Stardom FCJ (Field bus compatible).Initially it has been configured to take inputs from Yokogawa Rot mass flow meter to calculate density ,mass ,volume of both Oil & water.
I am suppose to make the following change
I have gone through the documentation. It has been written every where to add all hard wired & field signal to “DevicLabelDefinations” tab. I can’t open it. I tried a lot but when I double click over this tab ,nothing opened.
Any idea why I can’t add device label variables under “DevicLabelDefinations” tab.
I have also changed “Resource Configuration file” but still can’t open “DevicLabelDefinations” tab.
- Add an Analogue input signal “Water Cut Analyzer” which will be giving % of water.
- Total Mass I will be getting from Rota mass
- So Total mass-Water Cut Analyzer=Mass of oil
