Zen Omron counters
kitchsha
Jul 2011
USA
I've programmed SLC 505s and Micrologix 1100 and am now trying to write a simple program on the ZEN OMRON. When an input is triggered I want to increment a counter. So the first time it hits the eye, it counts 1, the second time 2 etc. I don't have any documentation on this thing though. I normally would use an OSR instruction so that the counter would only increment once when it hit the eye. I don't see anything like that with this ZEN though. Is there a way to simulate this? Maybe it's so different I don't need to??
this is not much help yet
I am trying to get a copy of the zen software.
I have a memory of being able to set the contact as a Dif UP or Dif Down.
Omron does not need to have a specific ONS contact like AB
which I think is a good thing.
I have checked the software
Use a Timer as a one shot pulse
it is one of the timer otpions
I've programmed SLC 505s and Micrologix 1100...I normally would use an OSR instruction so that the counter would only increment once when it hit the eye.
A one-shot is not necessary when using Allen-Bradley counters. I expect that it isn't required with the ZEN either.
The Omron ZEN Programmable Relay does not use the Omron CX-Programmer software. The ZEN software is totally different.
Wire your trigger input to the first line of the ZEN Counter Input. To count UP, no input is needed on the second counter line, but to RESET, you need an input wired to the 3rd line. See the Omron ZEN manual, page 70.
Link to Documentation:
http://www.ia.omron.com/data_pdf/data_sheet/zen_ds_csm106.pdf
Link to one supplier for Zen-Soft Software, if you prefer using that instead of the keypad:
http://parts.digikey.com/1/parts/1106977-software-zen-control-cd-ver4-zen-soft01-v4.html
Link to 30 day Trial version of software:
http://forums.mrplc.com/index.php?app=downloads&showfile=85
Thanks guys. Now that I've seen how they're actually used, I'm embarrassed by how easy it is. I appreciate everyone's help.
I am very new so I will try to give as much information as possible. I cannot get a Prolific PL-2303TA USB to RS232 to connect to an Omron ZEN...
1,603
Hi, after 30 years involved with automation I'm actually writing my first PLC program and am struggling a fair bit. My background is mechanical...
1,907
Hi I am setting a system up as per the attached picture, 5 inputs that are always present. These are sensors I have in an injection mould, if...
1,877
Hello all, new on here, and relatively new to plc programming. I am trying to write a program which counts as it receives a cycle end input, and...
1,912
I am trying to write a program for a omron zen plc. 1st light on for 30 sec 2nd light on for 12 sec 3rd light on for 3 sec then start all over...
1,336
