Zener safety barriers
That's not what I meant. A Zener Diode is not a normal diode, hence why it doesn't gets connected the same way.
A diode is like a one-way street, current can only go in one direction.
A zener diode will work as a normal diode in one way so current can pass.
In the other way however it will pass current as well but only if the voltage is large enough.
So a 10 Volt zener diode will let current pass in one direction without a problem and in the other direction when the voltage is over 10 Volt.
This is called the zener breakdown voltage and you can buy different zener diodes with different voltages.
Keep in mind Zener diodes are always reversed biased
in forward bias they act just like a regular diode
I have seen them called breakdown diodes because the reverse barrier braked down and conducts at the set voltage. They become shorts with any voltage above the breakdown voltage. they can dissipate very little power before they destroy then selves. .
I think a correctly sized MOV will work better for you.
but if you really want proception use a signal isolator thy can give you several thousand volts of isolation I think they would be your best option.
Thank you guys for your replies, just to clarify. If you apply +12 vdc on the cathode(negative) of the zener diode with a zener breakdown of 10 v dc, it will conduct current?
Zener Diodes are used in conjunction with a fuse and a current limiting resistor to create an intrinsically safe barrier. Multiples are used for safety (typically 3) and the design intent is to short to ground at it's threshold so that the fuse clears the fault before any sparking damage can happen at the hazardous area.
For negative polarity Zener barrier , the cathode of the zener diode is connected to ground...So how this circuit work for DC supply?? as per my...
1,691
What is the function of zener diode at this pic and it don't find at the real marshalling panel
4,377
Hi, everyone, Please forgive me if I send this question to this forum. I have FLOWMETER YOKOGAWA that controled by PLC and at the moment I have...
2,986
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
24
648
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
