zero speed sensor?
nykommling
May 2004
minneapolis
39
I wish to sense the speed of a gear. Should I be using a zero speed sensor? What's the difference between zero speed sensors and a normal inductive sensor?
A zero speed sensor is an inteligent piece of kit that will have a prox type sensor with some electronics to check for low or zero pulses from the actuator on the shaft/conveyor, these usually have trimmers to select the "speed or lack of pulses" that the unit will turn on the output i.e. if set to 10 ppm then if the time between two pulses was less than the expected time for 10ppm (pulses per minute).
these are used generally to detect jams in elevators or conveyors & stop the drive to prevent burnout or other major damage.
if you use a sensor then you will need some logic to determine if the shaft/conveyor is moving & what speed you wish to alarm at or even use as some crude form of speed indication.
Hi, AB Soft Start question, I have (4) SMC Flex 150-F251NBDD controlling 200 hp chip head motors in a sawmill. I am trying to tune the braking...
869
Does any one know of and have experience with a zero-speed switch? What is the most recommended brand and what would you advise? Customer is...
2,022
I have an application where I have to detect the start of motion (non-zero-speed) quickly, and also be able to detect overspeed of around 3000...
5,521
I'm doing a sand silo system at a foundry..an outside company has provided the control cabinet and programming...the conveyors normally have zero...
3,757
Hello Experts, i am new to this forum, we have control techniques mentor-2 DC drives for Conveyor application, Q.1) in motor...
4,010
