Analog I/o Modules
PERSPOLIS
Jun 2002
ontario
295
Hi Experts
In reference to Allen Bradley publication 1746-6.4 January 1996 (SLC 500 Analog I/O Modules) section 4.7 Table 4.d can anybody explain what does 13.67 bits mean .
Many Thanks
I haven't a clue!...
If anyone wants to tackle this one, here's the table Persopolis is referring to:
[attachment]
beerchug
-Eric
a bit of mathermatical trivia
The geek who wrote the manual must have been having some fun.
just as the range 0-16384 spans 16384 = 214
the range 3277-16384 spans 13107 = 213.67
actually windows calculator says 213.678
So, does this means that the remaining 0.322 of that bit is available for use elsewhere in the program?...
beerchug
-Eric
Oh yes, absolutely!
...using the set of Heisenberg uncertainty instructions coming in a future release...not certain which one. :D
Actually, the remaining 0.322 bits are available, but Rockwell charges a special bit access fee for it and you need the key disk. This only applies on the Micrologix 1200 Rev 1.1.02.05 or later, and the SLC 5/05.2.3 Rev A.13F (hex).
Hello, the PLC in question is 1769-L30ER. I have a local 4-20mA Analog Output module (1769-OF4CI), and also a remote ethernet PointIO analog...
410
Hi all, I would like to know if there are some precautions to take when doing a welding nearby instruments. Im asking this because today we weld...
3,291
I am doing a PLC5 to Controllogix upgrade (not using conversion software) I hooked up the 1756-DHRIO card to the existing (and working) Remote...
2,779
I have to simulate a code in rslogix 5000 emulator, I am trying to add modules as per my H/W config, but cant find analog modules, i only can see...
5,322
I have a offset printing M/C it's using a siemens S5 115 cpu with 14 analog interface modules . now the interface modules only showing error...
2,806
