First, My customer wants me to make a change to his Panelview and PLC program.
Second, I have a pump that is not starting when it is supposed to (a different pump is starting).
I think I can handle both of these problems if i can understand how the PLC5 program (using RSLogix5) and the Panelview are addressing or communicating with each other.
As for my second problem, I need O:034/10 to come on when I choose the PET2 process in the CIP Panelview but I do not know how it is being controlled.
I have found the control for it in LAD 13 Rung 59 with a BTD by distributing the binary data to the outputs but I do not know how to manipulate this data to select a different pump.
I need to make O:034/10 true (the number 1024 in B346:0 would do this) but how is this being done with the Panelview.
Any help would be much appreciated and any additional info needed would be gladly sent. I have done various searches through this site and have also read the panelview manual but I still am confused about the addressing issue. I think if it were one Panelview and one PLC I would be able to understand more but with the multiple Panelviews and PLCs it gets confusing quickly.
Here is how the network is setup:
[attachment]
More info following.
Thanks, Bill
[attachment]
Thanks, Bill
