View SE - Components change size/position in runtime screen
Plug and Pray
Feb 2021
US
Hello everyone,
I'm trying to figure out some weird behavior with some numeric displays.
The problem is that I center numeric displays over panels but when I look at the actual HMI screen, the numeric display's numbers go outside of the panel. The development screen doesn't show this which makes it difficult to predict what anything will look like.
The only fix I've found is to decrease the font size but then it's too small.
Does anyone know why this could be happening? Thanks in advance!
Hello, I am trying to create a multistate indication in which i have a square that changes colors on 3 conditions: a) less than the current date...
1,838
Hi all, I'm designing a new HMI but I'm having problems browsing the tags. This is my first time using the CCW software. I mostly have experience...
8,443
Is it possible to communicate the PLC Series Micro800 having its IDE CCW with Factorytalkview ME to build the SCADA/HMI. If any one has hands on...
3,138
Is there a way to duplicate the "local message display" component that is available in FTview Studio? where you build your message file and the...
4,853
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
101
