Panelview 800 w/connected components workbench
lbric
Jul 2013
Bell Gardens CA
27
Hello,
I am trying to create a multistate indication in which i have a square that changes colors on 3 conditions:
a) less than the current date - color blue
b) current date - color gray
c)greater than current date - color yellow
does anybody know how to acomplish this? the multistate indicator appears to only let me select whole numbers for the state value as far as i can see. I am storing the RTC day value to an N7 integer this is what i want to use to change the color.
thanks
Ricardo L.
I'd probably write a rung of code to test the variable against the RTC, give you a 0,1,or 2 and change the panel view indicator based on that
I would do it in ladder.
Make your comparison so that when the value in a tag is less than the current date N7:1 = 0. When the value is equals the current date N7:1 = 1 and when the value is greater than the current date N7:1 = 2. Then for the multistate set the tag it reads to N7:1 and the colors you want when the value of N7:1 is 0, 1 and 2.
As the title says, I'm using CCW with a PV800 (and Micro850). I've made a scheduler in which a user can choose a month, day (1-31), hour (0-23)...
529
Hello, So i managed to read the string coming from control logix and put a string display in PanelView 800. Now I am struggling to do the other...
154
Good morning all, programming a Panelview 800, I have a maintained push button programmed on screen 1. I copied and pasted it to screen 2. Could...
1,172
I'm trying to convert an old panelview 600 application to the 800 and I'd like to keep the current serial comms configuration instead of adding...
606
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
901
