Host System: Windows 10 x64, 16GB of ram, I-7 2.30GHZ processor
Guest: Windows 10 x64, 8GB of ram, (tried processors set to 1, 2, 4, 8)
VM Settings; Currently, Processor Cores 1 (virtualize intel vt-x/ept or amd-v/rvi checked), HD 100GB, Network Bridged (automatic) only adapters needed are selected
1. Found a post that recommended modifying the VMX file with the following lines, but it didn't make much of a difference.
MemTrimRate = "0"
mainMem.useNamedFile = "FALSE"
sched.mem.pshare.enable = "FALSE"
prefvmx.useRecommendedLockedMemSize = "TRUE"
2. I have also went through IE options and unchecked;
Check for server certificate revocation &
Check for Publisher's certificate revocation
Studio 5000 v32.11 Uploading from Controllogix L73 with a 1756-EN4TR module.
I have tried a direct USB connection. The first time uploading took approximately 20+ minutes to upload.
Uploading through a VPN took between 45-60 Minutes. (if it didn't fail)
Ping TTL= 57 and doesn't drop if I let it run continuously.
*if you know of any setting or any tips I am available for testing and don't mind messing it up a few times to make it better. At this point I have exhausted mrplc, reddit, rockwell forums, and google. Anyone out there having any luck?*
MemTrimRate = "0"
