plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old May 4th, 2021, 08:38 AM   #1
electro89
Canada
electro89 is offline
High Performance HMI - High/Low Tank Indication
Hi All,
I have been trying to adopt some of the HPHMI/Situational Awareness philosophies in my recent HMI designs and I've always been unsure about what colour to use for point-level indication on the bins (HH/H/L/LL). Typically, using High-High as an example, I would have a small rectangle on the top of the bin with "HH" or two up-arrows that would be grey when off and cyan when active. Same for all levels, but if it were to indicate an alarm-state, I'd put an alarm indicator next to it.
I have been through many many posts and slideshows online and can't seem to find the answer. Would like to hear what everyone's thoughts are on this.
Thanks in advance!
Old May 4th, 2021, 11:30 AM   #2
parky
United Kingdom
parky is offline
parky's Avatar
I think it is a personal choice or at the very least the customers choice or requirement.
Some examples I have used are:
HH, cyan or even black when not covered, flashing red when covered
H, Cyan or black when not covered, green when covered
L, cyan or black when not covered, Green when covered
LL Flashing red when not covered, green when covered.
A lot depends on the background, these are often grey so will pick colours that show some contrast in both states.
Old May 4th, 2021, 11:43 AM   #3
Phrog30
United States
Phrog30 is offline
Maybe this will help:
https://docs.inductiveautomation.com...alog+Indicator
This component could be used for tank level. Most platforms will have a component/control similar to this.
As far as colors, yellow for low and high and red for low low and high high is common. But these colors only show when there is a condition. If the condition is normal, it uses a different color, usually a gray of some kind.
I use arrows as well. One arrow up for high, two arrows up for high high, the same for the lows but pointing down.
Old May 4th, 2021, 12:12 PM   #4
electro89
Canada
thanks guys! My background is indeed grey (it is mostly based off ABB Ability's graphics, which you can see on page 17 of this document) and would like to keep the off-state a grey shade as well and reserve colours for things the operator should see first. I played around with using white to show it was active but that even confused me eventually.
Phrog30, I should have specified, this is for discrete level measurements, ie limit switches. I thought this would be a common form of measurement but for whatever reason there doesn't seem to be much about it in terms of an ISA standard. Disclaimer, I do not own a copy of the standards, but have read many articles and posts summarizing them, so maybe the answer is in there
Old May 4th, 2021, 12:22 PM   #5
hkazan
Lebanon
hkazan is offline
hkazan's Avatar
hello,
You can check the ISA101 HMI design standard.
The tank bar colors:
- For HH and LL : Black.
- For H and L : Light Gray.
- For normal level: Light Blue.
- When the indicator reaches the HH or LL Level: RED.
- When the indicator reaches the H or L Level: Yellow.
In the attachment You will find an example Pic.Plus, you can download the ISA101 From this link: https://www.reynoldsonline.com/ASSET...iew+SE+V11.pdf.
Good Luck.
Old May 4th, 2021, 12:24 PM   #6
VAN
United States
VAN is offline
Yeah, I'd say follow inductives guide I remember if being pretty good.
But I'll add that instead of blindly following HH,H,L,LL and other standard alarms you might only show color when someone needs to be alerted.
So if something is high/low and nobody cares and isn't going to do something about it, don't have it colored. Colors should only be used when some ones attention is needed.
I was able to use white as on at a couple of sites, but some others pushed the issue and really wanted green. At the end of the day when they see red they know something is wrong but listen to the operators that'll be using the screens.
Old May 4th, 2021, 12:40 PM   #7
Phrog30
United States
Phrog30 is offline
Quote:
The implementation is basically the same, except instead of having one component, you have several. You will have a normal state color, gray, or other subdued color. Then you have alarm state color. I still use the same colors as I described earlier. I typically blink on alarm or warning.
My graphics have properties that I can choose the color I want, there is a global default, but then if you want it different you can for a certain instance.
Old May 4th, 2021, 06:09 PM   #8
m_turk
Croatia
m_turk is offline
Quote:
Yeah, other gray and "no color" stuff gets accepted really well, but the green is always a must I get from the operators.. I don't know, maybe they are right and the new standards got that wrong.. I think it is a psychological problem to see something only when there is a problem, they want to see something when it is all ok too, like "you see, it is all working"..
Old May 4th, 2021, 08:16 PM   #9
Phrog30
United States
Phrog30 is offline
Quote:
It's not a one size fits all, to your point there will be users that will not accept the high performance way.
Best practice should be to use global/default colors, so you can easily change if necessary. Example, if you have running as white and they want green, you can change in one place instead of going to each instance.
Old May 4th, 2021, 08:54 PM   #10
kalabdel
Canada
kalabdel is offline
Quote:
Originally Posted by hkazan View Post
hello,
Good Luck.
Old May 6th, 2021, 08:51 AM   #11
electro89
Canada
thanks all, good to hear everyone's opinion on this. I think what VAN said pretty much sums up what I needed to hear
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Delta High Performance VFD-E Series jude LIVE PLC Questions And Answers 10 November 13th, 2010 02:54 PM
How to Build a Free HMI for AB Archie LIVE PLC Questions And Answers 32 December 4th, 2007 06:56 AM
HMI communication problem with S7-300 (when scan time is high) supporter LIVE PLC Questions And Answers 5 November 16th, 2007 02:56 AM
fishenguy fishenguy LIVE PLC Questions And Answers 54 November 13th, 2007 09:33 PM
E-series HMI and Modems The_Wanderer LIVE PLC Questions And Answers 5 February 25th, 2004 11:46 AM
