Logix 5000 Lost Project Paths
EJSControls
Apr 2020
Conover, NC
20
I am having an issue with Logix 5000 and I hope somebody has a solution.
Normally, when I open an existing project, the project path bar is automatically populated with the correct location of the controller on my network. Something changed and now the path bar simply states <none>. If I need to go online with a PLC, I have to open "who active" and search the list for the controller.
I also noticed that the list of recent paths is empty.
Is there a setting somewhere that can bring back all of the paths associated with my projects?
Surely, somebody has seen this before.
Yep. When you go who active and find your PLC, select the PLC and then on the right hand side of the window, click "set project path". Then save the project.
Right, that is what I am doing for each project that I am opening. However, for the last 2 years or more, Logix 5000 "remembered" all of my project paths. We have a few dozen PLC's in our facility. I would hope there was a setting in the software to use the path that was saved in the project file.
Usually, that happens due to network changes in RSLinx. Just keep it untouch if you don't want to remember PLCs IP.
The path to that controller can be saved as part of the project. Each project you open can remember that path that was saved.
However, the history of all paths you used over the past several years isn't saved in a file. It might be saved as a hash in the registry somewhere. I looked for just the raw text in my path and it didn't find it.
Unfortunately, that history is easy to erase. They even have a Reset Path List button. Click it and it is gone. No "are you sure" type prompt either. Once that path is gone, it is gone.
OG
Hi, I have a big problem here, I had Logix 5000 and studio 5000 with version 24 installed in a laptop and activated with factory talks management...
1,753
Does anyone know if there is a way, in AB Logix 5000, to save the "flags" that are in use on a ladder logic project when the software is closed or...
2,286
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
154
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
574
