OPC Kepware ref.Global.Tag vs ref.Tag - Rockwell v30 L33erm
VAN
Apr 2012
Wa
509
OK, this might be simple but I always remembered when accessing rockwell "global tags" or tags at the top level you could just ignore the global when referencing them.
What I'm seeing for unknown reasons is a tag with and without the global, which is fine who care. My problem is 3 of the tags match time and value but 1 tag is rogue. I ref. the tags without Global but for some reason its like I'm polling the .Global. tag into historian.
Anyone seen this and am I wrong in thinking ref.Global.Tag is ref.Tag and its the same tag? (I can't find separate tags in the PLC.)
:confused:
The typical syntax is Program:programName.TagName
Where ProgramName is the name of the program that the tag is declared in.
That's what I thought, but at the PLC level (all programs can access) can you drop the .Global. and it should point to the same tag?
TLDR: I try to establish the OPC communication between Kepware OPC DA Client to ABB 800xA OPC DA Server. In the Kepware OPC quick client of poll...
851
I have a project in which I need to automatically manage some farms. They are asking me to find a way to control some small amount of IOs from one...
1,404
Hi, In a project I have four Progressive Pressing Machine. Each machine with different PLC like Mitsubishi 'Q00UCPU' with...
3,037
I just want to log Rockwell PLC tag data to a SQL db. Is there a preference between Kepware and Software Toolbox ? Thanks...
1,951
Hello dear experts! Please advice me how to generate a digital alarm in FT VIEW SE A&E by one bit from a tag in KepwareOPC where this tag is a...
3,346
